跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Air seeping into side of LCD after loca repair
Hey everyone.
I've recently tried repairing a cracked iPhone 6 screen by only removing the glass and glueing new glass on with loca glue. After putting the clean LCD in a special mold for glueing and applied some loca glue in a bone shaped form and putting on the glass, I hardened the glue with a little up flashlight. I thought it had hardened completely, so I put the frame on and assembled everything back together. Now, one day later, I noticed air seeping back into between the glass and LCD from the sides, so apparently the glue still hasn't hardened completely. It looks like I pushed out the remaining glue too hard, and now it's sucking air back in because of that.
I'd like to do this better next time, so I was wondering what the reason for this is. Maybe the glue was of a too cheap quality? Or should I have used one of these nail polish drying lamps (which are much stronger than a little us flashlight)?
What type of loca can you guys recommend?
I'd appreciate help a lot,
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
LOCA is a horrible way to repair screens. I don't recommend using it every. Never use LOCA. Loca is garbage.
As to why your glue didn't dry, you have to use a UV light that operates at the same wavelength as the glue. Each glue is rated for a certain NM and every UV light operates at a certain NM. No bulb is stronger than any other bulb and brightness has nothing to do with the glue drying.
In case I wasn't clear: LOCA sucks.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for that, I'll do some research on the wavelenghts. I know that it's horrible, but I'm not planning on buying 800$ machinery anytime in the future just to use OCA, thats why I'm trying to perfect my knowledge on LOCA. Anyways, so you think It wasn't dry completely yet and thats why air could get into the sides? Maybe I should switch to a different type of LOCA...
完成的
添加一条评论
Just replace the assembly next time. They aren't expensive at all. And super easy.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 72
