跳转到主内容
Released in Japan on December 12, 2004, in North America on March 24, 2005, and in Europe on 1 September, 2005.
101 个问题 查看全部
Why wont my PSP 1000 charge?
ok so i've got a psp 1000 and i can get it to turn on it plays games fine but charging does not happen it wont even run on the power cable when the battery is not in the psp does anyone out there have any idea what is wrong and do you think it can and should be saved
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
Well its ether one of two(maybe both)
1. you port is bad, depending on how long you have had the psp the port can get worn out. try blowing on it or buying a new port then replacing it.
2. The battery is bad. the battery can be shorted out. ether replace it with a known working battery or buy another
From experience I say its the battery but for my brother it was the port.
这个答案有帮助吗?
得分 1
1条评论:
This is old, I know, but there seem to be other issues as well. My Port is clearly fine (measured if it provides power to the board and it does, battery is new. Still no luck.
完成的
添加一条评论
my experience says you need a new battery. there is a chip inside where software will allow the PSP to run. Hence why people use Pandora Batteries to hack the PSPs
see if u have a friend that will let you borrow their battery before you purchase one, that will be appropiate.
这个答案有帮助吗?
得分 0
添加一条评论
he is super right
my psp wont open too and i replace my battery with my brothers battery
and they both work fine
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 46
总计 9,158
