跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
596 个问题 查看全部
Replaced Logic Board w/ Used, Can't Log In
I replaced my dead late 2011 logic board with used mid-2012. Now I can't log in, I'm assuming because the serials are different. It says:
"You are unable to log in to the user account 'UserName' at this time.
Logging in to the account failed because an error occurred."
The internet tells me changing my serial is close to impossible and I can't seem to find out if reinstalling OS X will make a difference in this situation.
Is there a way to still make use of all my apps and software even though they are linked to my old serial? I backed up a day or two before the board died (just had a bad feeling... I'm glad I did!)
What do I do to make use of this very lovely screen saver machine?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Sounds to me like this logic board us linked to another user via iCloud. It may be a pull from a stolen machine. What was your part source?
这个答案有帮助吗?
得分 1
3条评论:
Can a board really be locked to an iCloud account and therefore completely unusable even with his own hard drive? I guess this what could be called an iCloud locked MacBook, similar to an iCloud locked phone? I've never encountered that before and was hoping the MacBook world was exempt from this problem, so I'm very curious. I still deal mostly with old junk, so I'm often the last to hear about these "new" problems. :-)
完成的
@rdklinc The hard drive has nothing to do with it. It locks up the EFI chip on the logic board. I think the last ones that could be unlocked were the 2009 machine by changing the RAM config and zapping the PRAM. Now, if they are linked to an account, even if not stolen (I have an iPad in this condition), if it's not released cannot be reassigned. Same on iPad, iPhone and Macs.
完成的
I'm very familiar with firmware locks that can be released by changing the RAM, etc., and I think those still exist, but I was under the impression that this kind of old-school firmware lock was completely different than an iCloud lock (as happens on an iPhone), and it seems like the two things are easily confused (certainly I'm confused at least). I've yet to see an iCloud-locked MacBook -- have you actually seen one in person? Presumably a machine in this condition would not allow another user to log into iCloud on that machine from another bootable device....
完成的
添加一条评论
最有帮助的答案
The OS would not normally be linked to your serial number, so I would not expect this to be the situation. Do you happen to have FileValue enabled (encryption)?
What indications were you getting that the board was going bad? Is it possible that you aren't typing the password that you think you are, and have a bad key from liquid damage? I would type the password in a visible space just to verify.
I would boot the laptop from an external bootable volume, which will allow you to see your internal drive as a secondary drive and get at your data, etc. You can do this by connecting an external drive and powering on with the option key held down, which will display the boot options...I would be curious to see if you do get the boot options and not a padlock (which indicates a firmware lock on the new board). Boards with firmware locks can behave in strange ways, so I would want to rule that out.
Another idea is to follow these instructions and create a new admin account:
https://discussions.apple.com/thread/432...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Edward Galindez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,935
