跳转到主内容
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
371 个问题 查看全部
water damage, no sound, very slow, fan keep spinning in high speed
MacBook Air 13" Mid 2012
Spilled some water on it, then some keys stopped working, so I replaced the keyboard, the new keyboard works fine, however after the replacement; there is no sound at all (not even the boot up chime) , and it becomes very slow , even just moving the mouse lags; and the fan is always spinning at high speed;
The WIFI also malfunctioned after replacement for some time (no hardware installed), but somehow it is working again.
I tried to reset SMC, doesn't work, the LED on the magnet connector doesn't even light up.
which part might be wrong in such case? logic board or I/O board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Personally I would run both the board and the I/O board through my ultrasonic cleaner. There's probably still gunk/corrosion causing these issues.
If the board or I/O board have been damaged, an ultrasonic cleaning won't help, but the first step is to remove the gunk and verify that's not the problem.
这个答案有帮助吗?
得分 1
4条评论:
John, very long time, no see ;-)
完成的
Thanks for your answer, however I don't have a ultrasonic cleaner, and from the visual inspect, the boards do not seem to be dirty
完成的
Hi @mayer ! Good to see you and hope you're doing well!
完成的
Concerning the board, have you inspected the other side? If the liquid came through the keyboard, corrosion could easily be on the other side. Even then, it's not necessarily visible -- part of the benefit of an ultrasonic cleaner is that they clean UNDER the chips.
完成的
添加一条评论
添加你的答案
Jun Hu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 172
