跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
it won't pick up service.
I have a iPhone 6 and it won't pick up service. It says it cannot be activated. Perfect condition and worked before. I was told it was the baseband, and possibly the antenna? Can anyone help me fix this? Apple wants $300 to fix it. I don't have the money for that. Someone help please!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
https://support.apple.com/en-us/HT201407
这个答案有帮助吗?
得分 0
添加一条评论
Do a check first to make sure it's your baseband ic that's broken: When you remove the SIM card, does the phone alert you that no SIM card is inserted? If it does, then your baseband ic likely isn't the issue, and I'd suggest trying Omri's troubleshooting link.
If you remove your SIM card and the phone still continues to search for a signal, then you might have better luck taking it to a local phone repair shop instead of Apple. Baseband chip repairs require soldering (or you could try the "oven trick"). Either way, I wouldn't recommend it for a DIY project.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alexis Williams 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 102
