跳转到主内容
The Samsung Galaxy S 4G is an Android 2.2-powered smartphone with a 4-inch AMOLED touchscreen display and 1 GHz processor.
62 个问题 查看全部
All pictures & all screens look like a negative picture
All screens are in a negative picture look how can I fix it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 28
12条评论
Everything on this phone look like negatives . Please help
完成的
Everything on my phone look like negatives. Please Help
完成的
Yes.. everything on my phone looks like negatives.. help me please
完成的
My photos are all looking like negatives please help me to get my photos up and running.
完成的
How can I put my pictures that look like negative
完成的
显示更多的7条评论
添加一条评论
5个答案
已选择的解决方案
apps-settings-accessibility-negative colors.
这个答案有帮助吗?
得分 9
3条评论:
i did not find this topic. saw visibility enhancement with color but no negative color dialogue
完成的
would someone answer me?
完成的
apps-settings-accessibility-display & text size-turn off smart invert
完成的
添加一条评论
I was able to return my mobile phone to normal using the solution above but found a different dialog than negative.
You need to go to your settings and find Accessibility. This is the area where you can make changes to help those with vision, hearing, access, difficulties. On my particular phone, the I had to turn off "Color Inversion". Here is the pathway.
Settings - Accessibility features - Accessibility - Visual - Colour inversion
Your pathway may be a little different just try and find a similar path under Accessibility. Good Luck!
这个答案有帮助吗?
得分 4
3条评论:
I find this very helpful and in my Samsung A14, I had the following path Settings - Accessibility - Visibility enhancements - Colour inversion. Turn the colour inversion button off, then you will get back to normal
完成的
It worked perfectly in my Samsung A14 immediately in fixing all my images looking like negatives. Thank you so VERY much!!!!
完成的
My color inversion is off ,but still my phone shows negative display in blue color and also it's a sumsung A03 model
完成的
添加一条评论
Yes my color on picture are just blurting and dard faces
这个答案有帮助吗?
得分 0
1条评论:
See below, Hope this helps.
完成的
添加一条评论
how do i get my picture to look like pictures and not negatives
这个答案有帮助吗?
得分 0
添加一条评论
How to put my pictures back. They are all on negative
这个答案有帮助吗?
得分 0
1条评论:
Some of my photos are just negative. What do I do?
完成的
添加一条评论
添加你的答案
gmanom 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 26
过去 30 天: 162
总计 15,592
