All pictures & all screens look like a negative picture
All screens are in a negative picture look how can I fix it
apps-settings-accessibility-negative colors.
这个答案有帮助吗?
i did not find this topic. saw visibility enhancement with color but no negative color dialogue
would someone answer me?
apps-settings-accessibility-display & text size-turn off smart invert
I was able to return my mobile phone to normal using the solution above but found a different dialog than negative.
You need to go to your settings and find Accessibility. This is the area where you can make changes to help those with vision, hearing, access, difficulties. On my particular phone, the I had to turn off "Color Inversion". Here is the pathway.
Settings - Accessibility features - Accessibility - Visual - Colour inversion
Your pathway may be a little different just try and find a similar path under Accessibility. Good Luck!
这个答案有帮助吗?
I find this very helpful and in my Samsung A14, I had the following path Settings - Accessibility - Visibility enhancements - Colour inversion. Turn the colour inversion button off, then you will get back to normal
It worked perfectly in my Samsung A14 immediately in fixing all my images looking like negatives. Thank you so VERY much!!!!
My color inversion is off ,but still my phone shows negative display in blue color and also it's a sumsung A03 model
Yes my color on picture are just blurting and dard faces
这个答案有帮助吗?
See below, Hope this helps.
How to put my pictures back. They are all on negative
这个答案有帮助吗?
Some of my photos are just negative. What do I do?
过去 24 小时: 5
过去 7 天: 23
过去 30 天: 88
总计 16,161
12条评论
Everything on this phone look like negatives . Please help
由 vicki leece 完成的
Everything on my phone look like negatives. Please Help
由 vicki leece 完成的
Yes.. everything on my phone looks like negatives.. help me please
由 Lisa Billman 完成的
My photos are all looking like negatives please help me to get my photos up and running.
由 Margaret Weir 完成的
How can I put my pictures that look like negative
由 skinner451 完成的
显示更多的7条评论
