跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 个问题 查看全部
MacBook Pro slow battery charging
Hi
my macbook pro is very slow charging (about 10 hourse!)
there is (sometimes) horizontal line at start up (I repeat only sometimes)
I changed charger and battery but it doesn't solved
is this from logic board?
please help
Best Regards!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
The next step in the troubleshooting process would be to try and replace the magsafe port, if you indeed know its not the physical charger itself. This sits between your logic board and charger. If you are noticing slow charges and have eliminated the possibility of having a bad charger, it's possible your magsafe port is showing signs of its age. If I am not mistaken this is the part you should be looking for.
iFixit Guide
Edit = Repair Guide Link
这个答案有帮助吗?
得分 2
4条评论:
thanks again for your reply
is this possible to test it with multimeter to understand dc in board is faulty?
best regards
完成的
Hi
I changed " magesafe DC in power board" but no luck!
please help!
what can I do?
Best Regards
完成的
I also have had this problem for quite a while. it isn't the magsafe DC-board so I suppose it's a chip that got short-circuit. But I have no clue where or what needs to be replaced..
完成的
添加一条评论
Take it in to an ASP and have it tested for this issue:
MacBook Pro Repair Extension Program for Video Issues
https://www.apple.com/support/macbookpro...
这个答案有帮助吗?
得分 1
2条评论:
Hi
thanks for your reply baaut in my country there is no apple service
pelase help
best regards
完成的
What country is that? We may know sources that you are not aware of.
完成的
添加一条评论
Ordered one and will have at it this weekend. Hopefully this is the fix.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nicolas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 4,850
