跳转到主内容
Galaxy S4 won't boot up. Won't turn on
Tried all known troubleshooting and nothing works.
- During night I Noticed that the display came on and off twice so I just shut down the phone. Next morning it would not come back on.
Battery was fully charge when I shut it down. Even hooked it up into PC with USB and nothing. Computer can't find it because it's not coming on. Left plugged into PC and it feels warm so it's on charge but that's not the issue.
I was told perhaps it's the motherboard- just wonder if anyone had any idea of what else it could be. It's only 2 years old and flawless physically, buttons are good, battery is good just can't think of what could have happened.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Attempt to boot into safe mode
• Turn the device off.
• Press and hold the Power key.
• When 'Samsung Galaxy S5' appears on the screen, release the Power key.
• Immediately after releasing the Power key, press and hold the Volume down key.
• Continue to hold the Volume down key until the device finishes restarting.
If that doesn't fix your issues your next best bet is to order some tools and dismantle and reassemble it to make sure all the ribbon cables are plugged in properly.
这个答案有帮助吗?
得分 0
2条评论:
Sometimes you can boot strait into the BIOS to access safe mode by just holding either volume up or volume down and the power button.
完成的
Unfortunately as I mentioned I've tried this and 6 other methods. Nothing worked.
Used All these scenarios. https://www.youtube.com/watch?v=G1LNalLY...
完成的
添加一条评论
添加你的答案
tosca 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,263
