跳转到主内容
修复你的物品
维修的权力
商店
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
1016 个问题 查看全部
Partial/Broken Display after closing the casing! iPod Classic 120GB
I replaced the battery in my ipod, a check to make sure all was working properly BEFORE closing up the casing revealed all was indeed working correctly.
But after closing the case, the display is now messed up, with part of the image missing and the rest broken into lines with kind of splatter marks across the screen.
Is this just a screen replacement job, a connection problem, or worse?
Any help greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
评论:
Thanks. Yes - it looks like I may have squished the LCD on closing the case then.
完成的
Nice, fine if you could mark my answer then. =)
完成的
添加一条评论
打开所有标签
Mac的RAM升级套装
购买套装
所有选项卡都有足够的 RAM
购买套装
2个回答
最有帮助的答案
"Splatter marks"?
Sounds like a screen replacement. You probably cracked the LCD..
Google "cracked lcd" and see if your screen looks similar.
这个答案有帮助吗?
得分 1
添加一条评论
Hi Rousp
Thought I would just add (for everyone's info) that I received a new screen this morning.
Fitted it, and it works perfectly once again. Your prompt answer saved me a lot of time, I think I've marked your answer correctly, let me know if not.
Thanks
这个答案有帮助吗?
得分 1
评论:
hi Tony. You should click on "accept answer".
完成的
Hi Tony, glad to hear that. As bjoernen dk says you should click on "accept answer"
完成的
添加一条评论
添加你的答案
Tony 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,243
