跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36453 个问题 查看全部
What's the difference between deionized water vs distilled water etc.
What is the difference between deionized water vs distilled water and pure water.
I'm asking because I have an iPhone with water damage.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a link that in general, describes the process.
Electronics Water Damage
You will probably have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
If this process seems too daunting, take your phone to a reputable, professional phone repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 2
添加一条评论
Hello Daniel,
Distilled water and a cleaning solution (Branson EC) are often used to clean electronics that have sustained water damage. Distilled water is non conductive and safe to use. What makes the water conductive are the impurities in the water. Salts, minerals and electrolytes in the water conduct electricity between the components on the board causing corrosion. To clean the corrosion of a board effectively you will need to remove it, desolder the shields and use a quality ultrasonic cleaner. Follow that with a bath of 90% to 99% isopropyl alcohol to displace the water and allow to completely dry. I then connect to a known good screen, battery and dock port to test the board.
Water damage, if not treated propererly and immediately, can be a rabbit hole. Most good techs will not do water damage repair but only treat for data recovery.
Good luck
Holger
这个答案有帮助吗?
得分 1
添加一条评论
Daniel, in the chemistry world, "de-ionized" means there are no electrolytes, i.e. charge carrying ions of (generally speaking) minerals, in the water. "Distilled" means there are no electrolytes _and_ there are no dissolved gasses/organics in the water. A seemingly small difference, but various gasses, e.g. carbon dioxide, sulfur dioxide, etc. can disassociate into acids in solution, which isn't the best thing in the world. De-ionization is usually accomplished with an ion exchange resin, distillation is accomplished by heating and condensing the resulting gas, i.e., steam. Short version: Distilled is "purest" and best for electronic device cleaning.
这个答案有帮助吗?
得分 1
添加一条评论
Both are just fancy words for filtered water.
It doesn't matter how finely filtered the water that hit your phone was, it's still water and it still conducts electricity, causing short circuits, corrosion etc.
这个答案有帮助吗?
得分 -1
添加一条评论
添加你的答案
Daniel Kendel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 2,776
