跳转到主内容
Model number MFC270EN was released in 2012 and uses Android 4.0.
Why won't my headphone jack work?
I've tried getting new headphones and it still does not work.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Assuming you are using functional headphone. First try turning the device off then back on, if this fails, try checking the volume settings on the device. A factory reset may be your best option before taking the device apart.
If you do take the device apart and are looking for the fault. The headphone jack itself could be damaged internally from use, or the connections from the jack to the motherboard could be faulty or damaged.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matthew Main 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 177
