跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
WiFi works poorly after battery is replaced.
Replaced battery without incident. WiFi now works poorly at home, but continues to work just fine at work and elsewhere. Not that WiFI signal is weak, rather the phone does not even find the home network unless I am standing right on top of the box. Cellular signal is intact everywhere. Tried turning phone off; tried hard reset; nothing seems to help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi there,
This could be an issue with the wifi antenna that is located near the battery. I'd double check that it is seated properly in its socket.
After that turn your phone back on and test.
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
J Eric Russell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 33
