after 30% battery , screen with black lines and no touch
with old and new battery after 30% battery have no touch and black lines on screen or black screen , what can i do to fix it ? i have replace screen with new and the same
sorry for my poor english
So the battery charges when its connected to a charger, the phone works fine until it hits 30% battery, and then dies? How many times has it done this?
由 Josh W 完成的
Sound like an under voltage problem. Replace the battery the problem should be solved. Worked in 90%. You can also check your phone with iBackupBot. Read the Error logs. If you got low battery errors replace the battery.
由 Marius Werdecker 完成的
every time when the battery is 30%
the battery is "new" from ebay
由 kwnsak1 完成的
I would try a new battery from a reputable source like iFixit.
由 Josh W 完成的
