跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
after 30% battery , screen with black lines and no touch
with old and new battery after 30% battery have no touch and black lines on screen or black screen , what can i do to fix it ? i have replace screen with new and the same
sorry for my poor english
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论:
So the battery charges when its connected to a charger, the phone works fine until it hits 30% battery, and then dies? How many times has it done this?
完成的
Sound like an under voltage problem. Replace the battery the problem should be solved. Worked in 90%. You can also check your phone with iBackupBot. Read the Error logs. If you got low battery errors replace the battery.
完成的
every time when the battery is 30%
the battery is "new" from ebay
完成的
I would try a new battery from a reputable source like iFixit.
完成的
添加一条评论
1个答案
这个答案有帮助吗?
得分 0
1条评论:
i have downloaded the app, so where i can found these errors?
完成的
添加一条评论
添加你的答案
kwnsak1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 57
