跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
297 个问题 查看全部
Broken LCD Panel Replacement
My almost new 21.5" iMac took a spill from it's desk. Landing squarely on the wheels of my chair. Broken Glass front panel, broken LCD, and dead HD.
The HD is no big deal, and the system boots fine to another HD so the MoBo is fine. I just can't find a replacement for the LCD and glass.
Please help.
Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
已选择的解决方案
The glass panel is part # 922-9117
http://www.welovemacs.com/9229117.html
The LCD is part # 661-5303
http://search.store.yahoo.net/lovemacs/c...
These prices are outrageous.
Spend some time doing web searches for the part numbers. Here's a LCD for about half: http://www.bizrate.com/miscellaneous/oid...
这个答案有帮助吗?
得分 2
4条评论:
research +
完成的
Thanks for your research Mayer. I actually bought a panel from the third link you posted. Great people, and gave me a deal. Also gave me a return. In Apples' infinite wisdom, they made a very slight change to the panel in the 2010 version of the iMac. The vertical sync ribbon cable has a very slightly different end on it. No other differences in the panel at all, but this stupid 4 wire ribbon cable.
The part I got was LM215WF3 (SL) (A1). The part I need is LM215WF3 (SD) (A1).
Thanks Apple:(
So If you can get a line on a LM215WF3 (SD) (A1), let me know.
完成的
Well nobody has the (SD) only (SL)s unless you want 50 here: http://lcd.eechain.com/demand.asp?bg_key...
But you could email them and ask who's reselling them.
完成的
Yeah, I found them, but that was a dead end too. Guess I'll just have to wait until they get into the resale channel.
完成的
添加一条评论
We can offer replacement LCD's for any Mac product. Here's the data sheet for LM215WF3 (SD) (A1) on our blog:
http://www.displayalliance.com/research/...
这个答案有帮助吗?
得分 0
添加一条评论
Can Anyone tell me is LM215WF3-SL A1 and D1 Same and whats the difference ? .
Much Appriciated
这个答案有帮助吗?
得分 0
添加一条评论
oLEVIA 27" POWERS UP BUT THE DISPLAY SEEMS BROKEN DUE TO BEING DROPPED A COUPLE INCHES
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 6,630
