跳转到主内容
14 Megapixel camera. Has 12x Optical zoom, 48x Digital zoom, OIS, HD video with Stereo microphones and autofocus. Comes in Red or Black. This camera supports the following memory cards: SD/SDHC/SDXC/EyeFi (full support).
18 个问题 查看全部
Lens cover won't open anymore
My lens cover won't seem to open and close like it used to. This prevents me from taking pictures quickly because I always have to check to see if the lens cover is open, or not. I can force it open by hand, but wonder what I need to do to fix this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Mine does the same, but it doesn't seem like it's the springs since when I turn off the camera, the lens cover closes by itself.
完成的
添加一条评论
1个答案
已选择的解决方案
It sounds like the springs in your lens cover may be out. If the lens stay open after you force them open, and don't bounce back into place, then it's most likely that your springs are broken or disconnected from the lens. You'll have to open up your camera to make sure! You may either have to replace the springs or simply reattach them to the lens cover.
Please see the troubleshooting page for more information.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sam Blanton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 2,316
