My back cover doesn't pop off easily
I removed the screws but my back cover does not pop off easily as in video, any suggestions ?
iPhone 4/4S rear glass isn't as easy to remove as you may think. It should be open like a calculator. Hold it from the bottom with both of your hands and pull the panel with both of your thumbs to make it slide. Once it slides, then you can remove it easily. It requires a "significant" amount of pressure, especially the 1st time on an used smartphone (because of dust).
Hope this helps
Vincent
这个答案有帮助吗?
Thanks I guess I was afraid of applying too much pressure .
I totally understand and had the same issue back a few years ago. Just care and don't go too fast. It goes all alone after the first time :)
is the back cover broken or damaged? Probably the battery has extended and you need more power to slide the cover..
这个答案有帮助吗?
True if the battery is swollen it will be harder to remove battery cover. Keep pushing with more pressure.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 143
1条评论
I guess try sliding it up harder if you haven't already?
由 Ben 完成的
