跳转到主内容
4英寸屏幕;多种颜色可选;共发布三款型号;闪存容量:16、32及64GB
331 个问题 查看全部
iPod touch won't respond to touch?
I accidentally closed the car door on my iPod (5th gen) and now there's a huge section of my screen that looks like a bunch of rectangles and white lines, an that section won't respond to touch. When I try to put in my pass code, it'll delete numbers and input numbers from where the screen isn't responding. It won't let me slide to power off, so I'm stuck with a restarted iPod that won't respond. There's no crack in the screen. Help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
You probably impacted the LCD and broke it as well as the cables for the digitizer and display, as they are near the top bit of the iPod (near where you would slide to power off the device).
Depending on what sort of damage has been done all you may need to do is replace the display, or reseat the cables for the display and digitizer.
Worst case scenario you've broken the connectors on the logic board, or partially crushed them and need to have it professionally looked at.
Most of the delicate stuff is in the upper 2/5ths of the device.
Either way, the only way to figure out what happened is to pop it open and have a look
iPod Touch 第5代 屏幕组件替换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
caowitt 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 450
