跳转到主内容
MacBook only powers on with adaptor, doesn't detect new or old battery
So I've been fixing a macbook I got cheap on gumtree that was being sold as faulty. I needed to replace the HDD, fan,LCD and the keyboard and it turns on and everthing works fine except for the battery.
So here's what I've learned from troubleshooting so far
  • Only turns on and stays on only when plugged in
  • Doesn't detect original battery or new battery
  • Tried resetting PRAM, SMC
Any information would be helpful
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi
I had exactly the same problem recently with a Mid 2012 13" Macbook Pro and tried all the steps you mentioned.
Turned out that I had a broken battery sensor (flat connector on the bottom right hand side of the logic board which is connected to the button on the right hand side that shows battery power level)
After disconnecting this connector and doing (yet another) PRAM and SMC reset, the Macbook started working. Will be ordering another battery indicator cable but for now leaving it unplugged. Charging light went orange and it detected and charged the battery right up to 100% and has been sitting running on battery power for hours now with the battery indicator cable disconnected!
Also another thing to make sure is that you have the latest SMC Update installed , as SMC version 1.5 did resolve battery issues. (And SMC v1.8 on the 2012 model)
https://support.apple.com/kb/DL1474?loca...
这个答案有帮助吗?
得分 1
添加一条评论
Thanks Alex
It seems that it was the battery indicator was faulty, after unplugging and resetting the PRAM and SMC the power indicator on the charger changed to Orange, and the battery is now being detected by the system.
I've ordered a new charge indicator.
Thanks heaps again!
这个答案有帮助吗?
得分 1
1条评论:
You're very welcome! :) Glad to hear you got it fixed
完成的
添加一条评论
添加你的答案
Carl J 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 70
