No Service problem after dropped iPhone
I have my iphone 6 with slightly bent shell, the phone seems to work fine except that I realized that sometimes loses the net and I have to press on the display to bring her back again.What could it be?
sounds like a bad connection to the antenna if your having to press on it to recover signal.
its possibly come loose when its been dropped.
if its not that quite often restoring the phone via itunes fixes this
这个答案有帮助吗?
I've tried to do a restore through itunes without solving the problem, because obviously it will be a hardware problem.
Anyway thanks for reply
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 95
since I changed the houses have solved the problem.
perhaps because the old houses was slightly bent ...
由 michele casamassima 完成的
