跳转到主内容
High-end gaming laptops produced by Alienware (a subsidiary of Dell since 2006).
162 个问题 查看全部
My laptop cannot power on.
My Alienware laptop cannot power on. No response after pressing power.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
derekseven you want to start off by checking the output of your AC adapter with a multimeter. If the output is correct for your model (you did not tell us which model you have) then you need to consider taking it apart and measure/check the DC in connector. Try and trace the power loss from there on. If you give us your computers model number we may find a more direct answer.
这个答案有帮助吗?
得分 2
添加一条评论
ive got a similar issue , what model do you have??
cheers
Phil
这个答案有帮助吗?
得分 0
添加一条评论
Same issue with a r2 15 , gtx 980m. It stopped whilr i was gaming and didn t start back. Doesn t turn back on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
derekseven 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 238
