跳转到主内容
修复你的物品
维修的权力
商店
Repair and troubleshooting information for the Suzuki FA50 Moped.
78 个问题 查看全部
Is the VIN number on this moped only 6 digits?
On the frame, it states a number:
FA 50 414412
Thats all. Is this the VIN number?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
评论:
My FA50's at home, so I'll check and answer your question in a bit. However, I don't think that "414412" is the VIN -- it should be longer than that.
完成的
It’s technically a 10 digit vin. That means you have an actual JDM-Japanese Domestic Market Version! I have a RHD car that has the same amount of characters in the VIN. Japan didn’t start fully using the 14 digit VIN till after 96.
完成的
添加一条评论
2个回答
已选择的解决方案
Great answer, Mayer.
I took a look this morning, and the VIN was located on the front of the scooter frame, directly behind the horn. Here's a picture of it: I Photoshopped some of the numbers from the picture for security purposes, but you get the idea. The VIN is the entire sequence of numbers, starting from where it says "V.I.N." and ending with "833."
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Depending on the model, the VIN for an ATV is usually located on the swing arm. The swing arm is the main component that holds the rear axle firmly in place. Look for a 17 digit number. Look for this VIN also on the frame in the FRONT of the ATV as well.
For some kind of mopeds, you can find the VIN for a moped or scooter right above the footrest below the glove compartment. Look for a plastic plate thats about 4 x 1.5 inches. Youll have to remove the plate to see the VIN.
这个答案有帮助吗?
得分 2
评论:
Very good answer +
完成的
添加一条评论
添加你的答案
jared 将永远感激不已
浏览统计数据:
过去的24小时: 4
过去的7天: 20
过去的30天: 101
总计 10,589
