跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
问题已关闭
cant find repair guide on site
can you link this to me - i think it is either a dead battery or a bad board - it seems to be stuck in recovery mode if linked to itunes - other than that it will not even turn on....
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Can it hold a charge?
完成的
添加一条评论
3个答案
最有帮助的答案
Here is a troubleshooting guide, and here are the repair guides!
这个答案有帮助吗?
得分 1
添加一条评论
Try holding down the home button while plugging it in this will bring it into DFU mode not Recovery and you might be able to restore. I doubt this problem is harware related as I have seen this problem solved many times by software means.
G'luck
Liam Speirs
这个答案有帮助吗?
得分 0
1条评论:
Except of course for the fact that it won't turn on...
完成的
添加一条评论
Ok so i did what u told me to do and that was to hold the home button and is said the same thing. it said ipod in recovery mode must restore then i tried restoring it and it said unknown problem occcured . do u have any suggestions.
这个答案有帮助吗?
得分 0
1条评论:
Yeah, what liam speirs suggested probably would have done nothing, follow Ben Eisenman's advice.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,044
