跳转到主内容
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
156 个问题 查看全部
Why my game boy not charging?
So I had this game boy for along time but the ac adapter broke and after a lot of years a bought a new one but now the console is not charging at all... not even the red light goes on when I put the charger but the console still goes on and since the battery is dead it goes off right next
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
First of all, check the current output of the charger. If that value is equal or above the one on the original, then the battery is dead and you should get a new one.
这个答案有帮助吗?
得分 2
3条评论:
Where can I get a new GBA SP battery? Does Nintendo still manufacture them?
完成的
A place where you will surely find one is ebay. Or Aliexpress. Sorry for the late reply.
完成的
Just a quick note, all batteries on eBay are probably not up to full capacity, so they won't last as long as a brand new one. Just pointing that out.
完成的
添加一条评论
I would recommend getting a new battery as Ciprian R said above. If that doesn't work than it might be the actual connecter on the GameBoy. Take a quick peek inside it to see if there are any bent pins or any loose wires or such.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
arthurpotterkarate 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 4,929
