跳转到主内容
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
26 个问题 查看全部
Why did my computer froze?
I was working on my online quiz and it froze on me my mouse was pointed at the scroll down area.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
amiller364 there are lots of reasons for why this may have happened. Did you get it restarted? Any issues with doing that?
完成的
添加一条评论
2个答案
已选择的解决方案
amiller, Shut down ( hold power button 10 seconds) and restart, run a malware and virus check as this could be an infection.
I hope this helped you out, if so let me know by pressing the helpful button. Good luck.
https://chromebook.guide/chromebook-viru...
这个答案有帮助吗?
得分 1
添加一条评论
Also look into running a power flush on your device. This can be achieved by following Googles Chromebook reset instructions:
(In your case you would shut it down and use the keyboard short cut in the login screen)
Sign out of your Chromebook.
Press and hold Ctrl + Alt + Shift + R.
Click Restart to restart your Chromebook.
In the box that appears, click Reset and sign in with your Google Account.
Note: The account you sign in with after you reset your Chromebook will be the owner account.
Follow the instructions in the box.
Once you've set up your Chromebook, check if the problem is fixed.
THIS WILL RESET YOUR CHROMEBOOK but being a google device all your pictures, documents and the like should be online in the google drive.
This will fix %95 of software issues.
If it does not look into creating and using a recovery USB drive and finally if that doesn't work chances are it's hardware and being a chromebook it's often simpler to replace it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
amiller364 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 254
