跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2686 个问题 查看全部
touch id doesn't work after battery replacement
replaced the battery. no problems. afterwards, though, as soon as the phone starts, says it can't enable touch ID. when i try to enable it in settings, i get an immediate failure. double tap also doesn't work to bring the screen down. otherwise phone working fine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
force touch works. took it to a ubreakifix store and tried replacing entire screen - didn't work. visually inspected the cables and motherboard - no damage.
完成的
Paul, probably something on the board is damaged because of corrosion or there could be a short circuit. Disassemble device, clean board of any corrosion, with magnifying glass also check all solder joints for being,poor, cracked, burnt.
完成的
添加一条评论
2个答案
已选择的解决方案
Paul, You may have to try a hard reset to completely wipe your iPhone and set it up like new, before doing this check the link below for common touch ID problems and fixes.
Check the attached link,instruction and guide, Good luck
http://www.gottabemobile.com/2016/05/27/...
这个答案有帮助吗?
得分 2
2条评论:
didnt work. immediately touch id failed.
完成的
Erasing your data is called a soft reset, not a hard reset. :)
完成的
添加一条评论
Typically with a battery install you don't need to mess with the home button. If you removed the screen completely you might want to check the home button extension flex that connects to the logic board. Make sure it's seated properly. Also, verify that the extension flex connector and logic board connection look good...
Is force touch working?
Let's hope it's just a connection issue...
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
添加你的答案
paul foster 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 5,960
