跳转到主内容
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 个问题 查看全部
Glass replaced but screen not working now (backlight is)
I've followed the instructions to replace the glass screen perfectly, but now the screen doesn't display anything.
I can see the back light is working when I press the power button, but no picture is actually shown. The ipad mini also acts like its working (will lock and unlock and is detected by itunes)
I have hard reset and restored the software. Any other suggestions?
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
You may have damaged the LCD/Backlight flex cable when removing it from the frame, or quite possibly damaged the backlight filter on the board. I would first order in a new LCD/backlight from iFixit and test that. If it still doesn't work, it's a board issue.
这个答案有帮助吗?
得分 3
2条评论:
Would the backlight be working if the cable was damaged?
I saw the posts the the backlight filter solutions, but I presumed that the backlight wouldn't work if this was the issue.
完成的
添加一条评论
添加你的答案
Will Dawson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 135
