Will 6 Plus battery work on 6s plus
I got a 6s Plus 64GB
OEM of 6s Plus is at 2750mah
Planning to change my battery due to excessive drainage
Will a iphone 6 Plus battery at 2915mah work on a 6s plus
You can plug it in fine and boot the phone. It should fit in but the capacity will be different of course. 6plus 6s and 6s plus all use the same connector.
这个答案有帮助吗?
hey, you can check this blog which compared the 6s/6 , 6s plus and 6 plus battery differences http://www.etradesupply.com/blog/exchang...
这个答案有帮助吗?
Unfortunately Apple designed it to only work on the 6 plus.
这个答案有帮助吗?
@ajcooke01 Why is the solution? See response from Ben
This is completely untrue it works fine
Have an iPhone 6+ battery in my 6s+, works fine. Connector identical. Power ribbon slightly longer, will have a slight bow in it as opposed to original battery power ribbon, doesn’t affect fit of battery.
Same voltage , slightly higher mAh rating.
这个答案有帮助吗?
I have done this before: installing 6 Plus’ battery in a 6S Plus. Battery life was slightly more but Apple Pay would not function properly (authenticated on the iPhone but unable to detect by the cashier’s terminal).
这个答案有帮助吗?
Should not have made any difference as the NFC antenna is not in the battery
I replaced it with another 6S Plus battery and unsurprisingly Apple Pay works. I think it has to do with the frequency of the signal: with the higher capacity battery of the 6 Plus, it may be “ocerclcoked” thus unrecognizable by the terminal at the cashier.
Can u use a 6plus battery for my iPhone 6 ?
这个答案有帮助吗?
No. The 6 plus battery is too large for the 6.
I bought an iPhone 6 Plus battery for my iPhone 6S Plus. It seems to fit and work well. I did notice that the Battery Health "is unable to determine the battery..." within the Battery function.
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 54
总计 44,313
1条评论
hi iphone 6s plus battery will fit of iphone 6 plus battery or not let me know thanks
由 Julian Roberts 完成的
