跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
4099 个问题 查看全部
Itunes error 4013 after screen and battery change
i've changed a screen and battery on an Iphone 5S, after that it goes directly to "Connect to itunes" on startup screen. I Connect it, get the "update or restore" question and Choose restore, but it wont go on. I've put phone in DFU and get a phone is in recoverymode, start the recovery and it starts the "getting data", then the prepeare phone for update. Screen turns of, apple logo comes on and the the screen turns red or blue (changes from one to the Other if i try several times) and turns of and error 4013 shows up. I've turned antivirus of, firewall of, reinstalled Itunes on computer, checked computer for updates. But it just Returns error 4013.
Any thoughts ? suggestions ??
I've tried With 4 different batterys and 2 different screens, no change.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
评论:
Did you try it without the front camera cable plugged in?
How was the battery removed, was it pryed from the left side of the battery only and not the top or right or bottom side of the battery?
完成的
Think i've tried With it and without it, but not 100% if i've tried without.
完成的
Tested With Other screens now, With and without front camera and still the same. It starts to "restore" and the screen turns red og blue and reboots
完成的
battery was removed With heating up backside, then prying from left side.
完成的
I have similar problem, just want to add few things i have tried:
1) Took out Screen and connect to itunes - can perform Restore & Update successfully
2) Took out battery and left for a while - Open connection, phone can be used but will have similar problem after restart
完成的
显示更多的1条评论
添加一条评论
2个回答
最有帮助的答案
Nand chip must be removed, then formatted with a chip reader, then reinstalled. Jessa just released a video on this issue...
https://www.youtube.com/watch?v=qab9o9pY...
这个答案有帮助吗?
得分 1
添加一条评论
Hi
Have a look here for a solution
https://support.apple.com/en-gb/HT201444
Thanks
这个答案有帮助吗?
得分 0
评论:
If you've read what i've tried that solution has been tested ofcourse. If it was that easy i would be one happy camper
完成的
Apple support is a great way to get business for Apple, not to solve your issues.
完成的
添加一条评论
添加你的答案
thomas 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 6
过去的30天: 18
总计 5,630
