跳转到主内容
An economy SUV by Mazda, not the greatest sport utility vehicle in the world, just a Tribute. Made in the USA by Ford Motor Company. Simply a rebadged Ford Escape.
17 个问题 查看全部
Why won't my Mazda 2003 tribute won't start?
Car is getting sufficient fuel and spark but won't start.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@moonblue have you tried to get the OBD scanned? what have you checked? How do you know that it is "getting sufficient fuel"? You checked the fuel pressure?
完成的
添加一条评论
1个答案
Check wires! Mine somehow shorted out. The wiring harness for the engine goes behind and between the alternator and starter. I think there was a clip holding it up away from the heat because I found some plastic pieces broken back there same color/size as others. No idea what it was supposed to look like before. Anyway that part of the harness’s wires melted causing a short to either the starter or alternator. I'm still trying to figure out which one. Not easy to access! Hope this helps a little.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bluemoon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 870
