跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
432 个问题 查看全部
问题已关闭
Frequent freezes, hanging on apps, wierd disk errors
My two-year old iMac EMC 2211 used to be great until recently.
I've been experiencing very slow performance in virtually all applications, constant freezes, and in several instances after restarting, i got a folder icon with a (?).
I tried disk utility, and problems were repaired, after that no problems are reported. I also tried Tech tool pro with similar results. I still have the same problems described above.
I re-installed snow leopard successfully (took forever) but not even that solved the problems.
Is my HD failing? Is there a way to know without actually having to replace it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
最有帮助的答案
sounds like your hard drive is failing. try running SmartUtility to check your drive, or look in the Console for disk errors. in any case, if you're suspecting disk problems, make sure you immediately back up your data!
http://www.apple.com/downloads/macosx/sy...
is your iMac still covered by AppleCare? earlier this year my 2.5yr old 24" iMac started having disk errors and sometimes would boot with the flashing ?-mark. luckily Apple replaced the drive under warranty in my case
这个答案有帮助吗?
得分 1
1条评论:
I concur. SMART Utility will tell you for sure if your drive is failing so you don't waste time pursuing other avenues. I'm glad to see Apple has listed it on their site.
完成的
添加一条评论
Most likely, your hard drive is failing, if the read-write is slow, and it is flakey in finding an OS, than your hard drive is probably bad. you can check the cables connecting to the drive, but that's about it. You could try booting into single user mode (Hold "Option" & "S" upon hearing the chime) and type the following command: "fsck -y" (without quotations) and that basicly checks the disk and filesystem, but that can only do so much, you can also do this with force checking "fsck -f" (without quotations) if it reports any errors, than the drive is definently dead. you could try re-formating the hard drive if you haven't already done that.
这个答案有帮助吗?
得分 0
添加一条评论
Yeah looks like your HD is failing and if you repaired it and problems persist, sounds fatal. I'd backup and replace it.
这个答案有帮助吗?
得分 0
3条评论:
Okay, now i'm REALLY confused about the downvotes.
完成的
It would seem that one specific user (who shall remain nameless) decided it was a good idea to downvote a bunch of your answers. Because your answers are largely lining up with others who are getting upvotes, I'll try to restore a bit of balance on the downvoted ones.
完成的
OK- thanks man!
That kinda sucks, but thanks a lot for reversing that, I know you could just easily ignore it.
Don't know why anyone would do such a thing though, I try not to offend people too much here.
完成的
添加一条评论
My 80gb i pod is not working after updating with windows sofware. its not syncronizing any tracks after storing 2gb of music,even it will totally delete the tracks. ireally need your help?
这个答案有帮助吗?
得分 0
1条评论:
Please start your own new question as people will generally not see it when tagged onto a old question of someone else. Thanks
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,485
