跳转到主内容
由华硕制造的笔记本电脑。
2517 个问题 查看全部
I cannot switch laptop on. Power button blinking
OnOff button blinking. Cannot turn ZenBook UX305 unit on
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 16
36条评论
can you upload a pic of the laptop as I'm not how accessible the battery is ...
完成的
I am getting the same problem. My White Power light is blinking on the battery signal and doesn't open.
完成的
I did at your answers suggested and now my screen is still blank and the power light and airplane light are on constant - if anyone could help, that would be great.
完成的
Me too ky power ligth is blinking but i cant on my Asus Notebook...
完成的
hold the power button in for 20 sec or so and it will turn on. have the same issue sometimes but don't know what causes it
完成的
显示更多的31条评论
添加一条评论
5个答案
已选择的解决方案
Shlomo Shamir try the following and see if that helps.
- Do a hard reset, unplug the AC adapter from the laptop and press and hold the power button for 30 seconds.
-Test your AC adapter with a multi meter if it's supplying enough voltage required by yourZenbook to power it on.
If you do want to take it apart, this link will show you how.
这个答案有帮助吗?
得分 26
19条评论:
Great, important info. Thank you very much. Harmony is restored :-)
完成的
Bluestick. I tried in mine, and laptop is reset holding power button for 15 seconds. BUT, why is this happening, do you know? Because it happen to me very often, like 1 time a week, and I loose all the things I had in my desktop. I would like to solve the problem of not having this blinking anymore.
Thanks.
完成的
Very helpful. Thank you!
完成的
Thanks so much, this worked! Any idea what causes this fault?
完成的
It worked for my Asus zephryus rog too. Thanks so much
完成的
显示更多的14条评论
添加一条评论
i am sure all you need to do is pull the battery ... hold the power button for about 20 - 30 seconds ... plug the battery back in, and hey presto !!! your laptop should be functional again :)
这个答案有帮助吗?
得分 10
7条评论:
oh god thank you so much this worked. i held the power button for around 30 seconds as you said the i plugged it back to charge and it came on. thought i wouldve had to buy a new laptop my mom said she wiped the keyboard it was sticky and it ended up blank and in the state it was in i dont see any keys tha couldve send it into that state .
完成的
Omfg it worked, thank you!!
完成的
Held power button for 30 seconds. Started ok. Thanks
完成的
Thank you so much 🥰 This is very helpful ❣️
完成的
Thank you very much, saved my sanity
完成的
显示更多的2条评论
添加一条评论
Hello all, it looks like that my issue with the laptop was the display cable and the only way to fix it is to replace the display cable or display it with the cable.
—— My issue ——
- Power on -> doesn’t show any picture on the screen but looks like working, in order to start again you should hold power for ~10 sec. to get the fan spin.
- Power on -> display picture on the screen but only on the special position of the display - after a few min just freeze, in order to start again you should hold power for ~10 sec. to get the fan spin.
这个答案有帮助吗?
得分 1
添加一条评论
My laptop start having issue after 23 months. After sent to the Asus workshop to check and they said can't find any faulty parts. On 24 months, the laptop is not able to turn on without 8 hours rest.
I have done the hard reset but the same problem came back after 1 week.
Symptoms:
- Both power and Caps led on.
- Must disconnect the external keyboard and mouse or otherwise it won't be able turn on even after 8 hours rest.
- Battery was growing in size after 24 months. Due to the battery growing, it affects the keyboard (the center of the keyboard has a small hill) and later not able to close the screen. So, I removed the battery from the laptop because I scared that the battery explode.
I recommended this laptop to most of my co-workers and they bought it even though it's quite expensive. I just worried that one day they will condemn my recommendation.
If this problem can't be fix, most likely we will switch to other brand.
这个答案有帮助吗?
得分 0
5条评论:
Sir, if your battery is growing and affecting the keyboard you need to stop using your laptop immediately and remove the battery or it may explode or start leaking and damage the motherboard(s). A cell in your battery is defective and causes the battery to swell.
完成的
Thanks for your advice. The laptop is not able to boot up any more. It's time for me to get a new one. :)
完成的
Thank you all... 20 second trick worked
完成的
Same, press the power button for 20 sec
完成的
@honwanlau You don't have to buy an new one. Make a new question on Ifixit and ping me @diode_cool in the question
完成的
添加一条评论
Please go to bios and set default setup, restart and issues will be solved
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shlomo Shamir 将永远感激不已
浏览统计数据:
过去 24 小时: 134
过去 7 天: 655
过去 30 天: 3,063
总计 281,966
