跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 个问题 查看全部
iMac EMC 2015 fails to eject RAM
Pushing the white levers outward to pop out the RAM has now failed - the chips are still embedded in their respective slots.
I fear that repeated insertion and removal of the RAM has eroded the plastic which would eject the chips.
What should I do to remove and insert the RAM?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
My question is why you are ejecting the RAM that much. And why do you feel you need to do it again?
To get it out get a friend with a small pair of needle nose pliers. While one of you pushes on the levers the other grasps just the edge of the where no cuicuits or chips a re and gentle pulls.
Then make a decision and put the correct RAM back in one last time and leave it alone.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
lkvee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 64
