跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1169 个问题 查看全部
Touchscreen doesn't work
iPhone screen was broken and is now replaced... Everything works but he just doesn't want to react to my touching...
It worked before i opened THE iPhone so my question is... Is it one of THE 3 things you need to reconnect before you close it... And wich one is it?
Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
yes it tried like a douzend times to get it in... is there a small tip you can give me or some instructions how to put it on the iphone in a decent way? :)
i heard a clic so I went on to number one and closed the thing...
one thing i must say.. on the end of those ribbons there is always some rubber labeled with a number(isolating piece)... but with my new screen there wasn't any on number 2 so do I need to place it from te old screen on to the new because i think it is protection so when the iphone drops the cables do not come loose?
thank you very mutch
这个答案有帮助吗?
得分 0
添加一条评论
Yes, it is one of three screen ribbons- number 2 I believe. It can be difficult to get it seated on its receiver correctly.
这个答案有帮助吗?
得分 0
添加一条评论
While you don't necessarily need to put the foam back on, it certainly is helpful.
I would make sure you get everything clicked into place, then turn the phone on without putting the screen back in place- the home button will not be functional at this point. See if the screen responds at all.
If you get the screen to work, very carefully put the display back into place.
If not, you may have a bad digitizer.
这个答案有帮助吗?
得分 0
添加一条评论
it worked!
its fixed!!!
thx
这个答案有帮助吗?
得分 0
1条评论:
How about accepting my answer then, eh? :)
完成的
添加一条评论
添加你的答案
lennertfosselle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,794
