Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First you need to remove the battery as soon as possible from the phone.
Then you need to dis-assemble the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water.
Here is a link that in general, describes the process.
Electronics Water Damage
You will probably have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again
Hi, can you check whether bluetooth working or not ?
由 Buddhika Mahesh 完成的
Bluetooth is working fine.
由 Durga Sury 完成的
my phone fell in to water i removed the back and dried but my wifi and bluetooth does not work
由 game pro 完成的
me too is there anything could fix?
由 sun kung 完成的
yeah same happend to me nothing seems to be working sadly
由 gool gamer 完成的
