跳转到主内容
The BLU Vivo XL was released in January 2016 as part of BLU's budget line of smartphones.
Can't change default storage from SD to Phone?
I have a BLU vivo XL, and I have a micro SD card into it to expand my storage, but it has been downloading everything onto that SD card and now its full, I still have space on my phone but it won't install anything to the phone, only the SD card...Please Help. I have taken the SD card out and then installed stuff and it worked. But I can't change the default storage.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
Hi,
Check the following setting:
Menu > Settings > Device > Storage and see what the 'default' write disk is.
这个答案有帮助吗?
得分 3
添加一条评论
I have a special key for my Blu Vivo xl 2 and it opens the sim as well as the micro sd card slots it should com in your case. Also I a good way to transfer the partial information to your new phone is essential to not losing too much room as a confused waste in your phone's storage. Download an app if need be in the google play store.
这个答案有帮助吗?
得分 1
添加一条评论
Can you tell me how to open the XL2 to insert an SD card? I can't find an answer to this anywhere.
这个答案有帮助吗?
得分 0
添加一条评论
Thanks! :-) Much appreciated. Do you have a specific app you recommend?
这个答案有帮助吗?
得分 0
添加一条评论
How can I transfer files from Phone to SD Card with my VIVO V7 mobile? Do I need to use PC? How about changing the default storage? It's so complicated.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Levi Warkentin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 8,776
