Repair guides and support for your Samsung TV.
1322 个问题 查看全部
Sound won't stay on
My TV sound keeps going down on its own too 0 and won't stay on any number
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
3个回答
已选择的解决方案
rde70, Make sure button on remote is not sticking, remove batteries. The volume control seems to be an issue with some of the Samsung TV's. After checking out some forums, I suggest you open TV and remove the wire from volume button control board to interface board. This should fix your problem according to forums I have read.
https://www.cnet.com/forums/discussions/...
这个答案有帮助吗?
按维修分数 1
添加一条评论
rde70 let us know which model your TV ius. If you ruled out the remote by removing the batteries, you are most likely having issues with the IR board.
这个答案有帮助吗?
按维修分数 1
添加一条评论
You should give more information.
Try diagnosing the most obvious part. Set the volume up and make sure that the remote controller does not transmit signal to the TV. If you can, unplug the battery or make sure that no IR points to the TV (you can make sure it's not receiving a signal by pressing another button). If the sound goes down anyway, the remote is not to blame.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
rde70 将永远感激不已
浏览统计数据:
过去的24小时: 2
过去的7天: 20
过去的30天: 78
总计 1,630
