跳转到主内容
The output transister(s) are blown/not working. Where are they?
I have input from antenna but no output. Will not transmit, been told output transister(s) are gone. If I knew where they are I could replace them.
how do I know if they are npn or pnp? Any help please, thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
nicholashuntley the NPN vs PNP can best be determined by knowing what transistor you are dealing with. In the attached manual you will find the board layout and schematic with the transistors having a reference designated letter "Q". For example Q16 is a 2SC1015 transistor which has a NPN polarity. Check the datasheet for that on here. Anyhow hope this will help to get you started on your quest. Here is the service manual Midland 77-099 The scan is a bit hard to read
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
nicholashuntley 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 244
