跳转到主内容
修复你的物品
维修的权力
商店
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
3412 个问题 查看全部
iPhone showing black and white stripes
Hello!
My neighbours iPhone is only showing these black and white stripes.
When I change the display it's not showing anything (and I tested the new display on my own phone it definitly works!)
The old display sometimes shows these black and white stripes and sometimes it turns full white then black again.
My PC however seems to recognize the iPhone and it's also showing up on iTunes.
But it seems that I can't find a fix for the screen problem.
Here is the screen:
http://i.imgur.com/XjVKN12.jpg
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
Essential 工具包
我们最紧凑的套装中最有用的工具。
现在开始购物
1个回答
最有帮助的答案
Hi there,
This youtube video might help you: https://www.youtube.com/watch?v=nJCZJwrk...
In which he opens the phone up, cleans all the sockets that attach the screen to the motherboard with a toothbrush, and then secures the cables back into their sockets.
Note that he is working on a 5s, in order to open a 5 you can follow this guide, which is essentially the same but without the booby trapped cable connected to the home button that you will see in the video.
iPhone 5 显示屏组件替换
Hope this helps!
这个答案有帮助吗?
得分 4
评论:
Hi, I'm gonna try that, also cleaning with 100% alcohol and puttin' a new screen.. hope that works
完成的
Okay, it's not the display. I cleaned it with alcohol and it's still only showing these black and white stripes.
完成的
Aw man, I wish I had another suggestion for you, but that was my best guess... I'll keep searching the internet and let you know if I find an explanation.
完成的
Thanks, ye I think I found some posts on some weird russian forum saying that it's an issue with the board. Some circuits are screw'd (seems to be a common problem with 5c's tho) - welp thanks for your help anyways. I think I'll just sell it on ebay, cause from the outside it still looks fine.
完成的
This is happening to me to, I am doing this on my computer, this has happened two times before but the phone usually worked again after a couple of hours. I know this was like 3 years ago and it probably is working again so any tips or should I just wait?
完成的
添加一条评论
添加你的答案
dieuhientran63 将永远感激不已
浏览统计数据:
过去的24小时: 6
过去的7天: 21
过去的30天: 95
总计 13,026
