跳转到主内容
Motorola Moto G4 Plus got wet and won't turn on. Dead?
After the phone was dropped in water, I disassembled it and removed the battery and let it dry in rice for 48 hours.
I assembled the phone back and it won't power on.
I tested the battery and it outputs 4.40 v and it looks normal.
Any ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
on showing to the repair centre they told that the moto G4 is wet and we wont replace the burnt ICs (power IC) kindly suggest me what to do.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
As you know water, electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. Also rice is good to eat but does nothing to overcome the problems caused by corrosion of electronic components due to contact with liquids.
First you need to remove the battery from the phone.
Here is a link that shows how to do that.
http://www.etradesupply.com/blog/how-to-...
Then you need to clean and dry the electronics using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water.
Here is a link that, in general, describes the process.
Electronics Water Damage
You will probably have to replace the battery as it is very hard to recover a battery from water damage.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work again
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Jose 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 2,994
