跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1645 个问题 查看全部
maytag freezer working. fridge side warm. no interior lights.
I have a Maytag side by side fridge/freezer. Model gc2227hek5. Bought 2007.
Freezer seems to be ok... normal temp -18 deg and lights working.
Fridge side is too warm. Around 11 degrees. With no lights working ( all 3 bulbs checked and are ok). Temp alarm sounds. Door open alarm seems to work even though lights do not come on.
Not sure what to do?! Is there a fuse for fridge side?
Have cleaned dust from bottom of grill at front. Also took off biggest rear panel at bottom on back ... and cleaned.
Fans seem to be working. Air blowing from freezer into fridge seems ok.
If I use max cool... freezer cools more and fridge gets to maybe 8 degrees.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Might be the door switch.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tim Adams 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 110
