跳转到主内容
The Motorola Xoom is an Android-based tablet computer by Motorola, introduced at CES 2011 on January 5, 2011. It is the first tablet to run Android 3.0 Honeycomb.
43 个问题 查看全部
Why won't my tablet take a charge.
I changed the battery with a brand new one cause the old one wasn't holding a charge any more. Now I can't get the new battery to charge at all. I checked the charging port to see if it was damaged but it looks good. Do I have to rest the table back to how it was when I got it ? Don't know what else to do.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
please check the another outlet . If all else fails just walk into a Verizon store and tell them what's going on. They are usually pretty helpful in getting a replacement device for you
这个答案有帮助吗?
得分 0
添加一条评论
if your tablet has a micro usb charging port , they tend to get a bit touchy after a while. you might try and place the tablet on a flat surface and put something under the plug to apply a little pressure on the connector . trying it with the tablet face up or face down. those jacks seem to all get touchy after a while.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christine 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 730
