跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Battery discharging from 100% to 0% within a few hours
As the title really, I've got a problem with an iPhone 4S where the battery will fully drain from a full charge within a couple of hours. I have tried a full factory reset eliminating the software and replaced the battery and still no fix.
I'm thinking this may be a hardware issue, could it be one of the ICs need replacing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
This is just an issue with older batteries in an iPhone 4S. It is relatively easy to replace the battery. You can buy a replacement kit from iFixIt here iPhone 4S Battery
If you get lost during the process you can follow this video. (This is not my video but I looked at it and it is a good guide.) : https://www.youtube.com/watch?v=UJud8Hlr...
As you can see the replacement kit from iFixit is relatively cheap. You don't have much to lose even if it doesn't 100% solve your problem but from my experience, I would say that you just need a new battery.
If you need anything else you can contact me directly via e-mail: tyler.hoban@gmail.com
Best Regards,
Tyler Hoban
iPhone 4S Battery图片
产品
iPhone 4S Battery
$16.99
这个答案有帮助吗?
得分 2
4条评论:
I have already replaced the battery.
完成的
I also don't think the ifixit battery is anywhere as good as an original iphone battery. For the first few months, the ifixit battery lasted. But now, after just a few hours and not doing anything, it has dropped 20% and will be completely out by evening even without using it.
完成的
I think IFIXIT does not sell their batteries on Amazon because they know they don't last.
完成的
down another 10% in under an hour on wireless and doing nothing.
完成的
添加一条评论
添加你的答案
Dan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 89
