跳转到主内容
Here you will find several different repair guides for the Dell Chromebook 11 (CB1C13) - 2GB & 4GB models
11 个问题 查看全部
bypass enterprise enrollment on the Dell Chromebook 11 CB1C13
Ive tried to get into developer mode but I have not succeeded because it says that it has been disabled by the enterprise enrollment. Please tell me how to bypass the enterprise enrollment.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论:
l have the same problem, but l have two of the same make and model l was able to get one working and powerwash that one but have trouble with other, cant get into admid dev mode, if anyone can help or comments, advice is much apreciated, thanks
完成的
添加一条评论
3个答案
You cannot bypass enterprise enrollment without access to the admin console under which device was enrolled under. https://support.google.com/chrome/a/answ...
Thus, you cannot enter developer mode without your administrators permission.
这个答案有帮助吗?
得分 0
添加一条评论
Yes it won't let me Every time I try it keeps sending me to the screen Where it says Admin is blocked
这个答案有帮助吗?
得分 0
添加一条评论
what if l tried to wipe the memory and try a fresh install with different OS on a usb thumb drive , could l get into or have access to dev mode through a way like that?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joseph JS8517 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 29
总计 3,582
