The Nokia X6 is a music-oriented capacitive touchscreen smartphone and portable entertainment device by Nokia.
3 个问题 查看全部
How I can open my Nokia X6 device?
I would to open my Nokia X6 device , how can i do that ?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 3
评论:
When you figure it out, photo-document how it's done, and make a guide for it.
This is also a very excellent publish which I really experienced studying. It is not everyday that I have to be able to see something like.. https://www.spotifywebplayer.net/
添加一条评论
2个回答
已选择的解决方案
Here's the Service Manual on how to do it: http://www.nokiausers.net/forum/other-no...
这个答案有帮助吗?
按维修分数 5
评论:
thanks for the link mayer.. saved me loads of hassel!
Thanx a lot.
添加一条评论
Right off the bat expel the battery for no less than 5 minutes and afterward supplant and check whether that has any effect. At that point take a stab at expelling the sim card and check whether that has any effect.
At that point attempt the "3 finger profound reset". With the telephone controlled off, discourage and hold these three keys at the same time Green(call) key + Red (end call) key *Camera keys squeezed at the same time on catalyst and after that control on telephone utilizing the on/off catch while keeping the three keys discouraged until the point when you hear start-up tone.
This should ONLY be done if the gadget doesn't control up typically any longer and it wipes everything in the Phone memory that isn't a piece of the ROM. So you will lose every one of your information except if you have recently completed a reinforcement.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
Wael 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 12
过去的30天: 47
总计 12,202
