Released July 12, 2002. Identified by model number K45SSWH.
13 个问题 查看全部
问题已关闭
The speed switch on our KitchenAid K45sswh won't shut off
The speed switch on our KitchenAid K45sswh won't shut off all the other speeds work without a problem
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 1
添加一条评论
所有超过US$100或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
1个答案
Gwen, the switch is probably faulty and needs replaced, find a small appliance/vacuum repair shop and the can diagnose and give estimate for repair.
这个答案有帮助吗?
按维修分数 0
评论:
The switch works in every speed except for when you go to turn it off it won't stay in the off position
I have had this problem and have cured it by taking the end plate off (opposite end to mix-end) and adjusting the bottom single screw. I hope this helps..... Ormskirkdave
添加一条评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 236
