跳转到主内容
修理您汽车上的喇叭 音响 CD唱机 插座
Why does My pioneer radio turn on and off
I have a question why does my pioneer avh-x6700dvd turns on plays for like 3minutes then turns off and turns on again I check for cables touching,ground wire,fuses and nothing I think it might b the radio is their anything I could do or anywhere I could take it to get it fix
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 11
26条评论
i have this same problem but its with a AVH-X1700S
完成的
I have the same Problem with AVH1300NEX. Powers Off, then back on and remains fine ,Until I restart the engine. Happens every time, and the exact same Time frame after engine start. Pioneer said Might be a Firmware Issue.. Also had an Issue getting the steering wheel controls to work. ( Had to re flash the Metra Adapter.
完成的
I have the same problem on AVH-X2750BT . I tryed checking all connentions including all ribbon wires inside the unit i also did a firmware update ver 8.53 but none that worked .Is there a software update i can try ?
完成的
Hi,
I'm having a similar issues I had a pioneer radio the Bluetooth setting vanished, the radio was replaced with another pioneer than a day later would switch off automatically wouldn't switch back on until by itself approximately 20 minutes later but then would stay off again. Had this changed to a Sony radio now doing exactly the same.
完成的
I have a somewhat similar question about my pioneer bluetooth car stereo. My audio shuts on and off going down the road. It makes a like scratching noise then it'll shut off then turn back on. Ive tried fuses,pulling the radio out and checking the connections, checking speaker connections,ect but it still continues to do the same thing. I have no ideas anymore.
完成的
显示更多的21条评论
添加一条评论
15个答案
已选择的解决方案
Hi,
Does it happen when the car is stationary? Does it happen with the engine off? Do you have any problems with other circuits in the car that are fed off the accessories power e.g. cigarette lighter, power windows etc?
If it only happens to the radio with the engine on and more when you are driving it sounds like there is a loose connection or dry soldered joint in the power supply for the radio or in the radio.
You might have to connect a test lamp or DMM (digital Multimeter -Voltmeter function) to the power feed where it goes into the radio itself (or as close to the radio as you can get) to prove whether the problem is with the power into the radio or it is in the radio itself, i.e. either the power is on all the time at the radio power input point or it comes and goes.
If it is with the feed to the radio you need to check the wiring path from the radio fuse in the fuse block right through to the radio itself.
It may be for instance a loose connection at the rear of the fuse in the fuse block.
What type of fuse is installed? If it is a knife blade type check that the female connection point in the fuse block looks OK and that it has enough tension on the fuse. If it is a glass type fuse, again is it tight in the fuse holder, have you tried a different fuse of the same rating?
这个答案有帮助吗?
得分 7
10条评论:
I have the same problem. There is power to the unit but the flip screen won't open or the whole radio has no power. I believe that it has something to do with the flip screen. AVH-X6700DVD Is there any way The flip screen can be fixed in the open position? I think this may solve the problem. I had this same problem with two other flip screen units, and was told they couldn't be fixed. This is in an RV and does not get daily use.
完成的
Hi @tlb
First , how long have you had the unit? If less than 12 months there is still a manufacturer's warranty on it.
If the whole radio has no power and you say that there is power at the unit, then if it is out of warranty the best thing to do is open the unit and see if there is either a fuse in the unit that may have blown, or any obvious sign of component failure like a burnt out resistor etc. If you have a DMM (Digital Multimeter) and know how to read circuit diagrams there are service manuals for the unit available online but unfortunately you have to buy them.
完成的
I have the same problem... but mine is a Lil different... if you switch on the radio the powers comes on, but as soon as you leave the on and off switch button, it goes off again by itself. What might be the problem
完成的
Hi @ Elton Ipinge,
I don't know your radio but if it has a push to turn on / push to turn off ON/OFF button, it may be that the button itself is faulty, in that the button contacts are made when you push it in to turn on the radio but do not stay operated when you remove your finger.
If your radio is no longer under warranty I suggest that you remove the radio and open it up to test the button's operation using a DMM's Ohmmeter function (Digital Multimeter) to prove that the button contacts stay operated when the button is pushed in and then disconnect when the button is pushed again.
I suggest an Ohmmeter as the whole button including contacts may be encased and therefore you cannot actually 'see' the contacts but have to prove it electrically, using an Ohmmeter to test for continuity through the contacts, most probably where they are connected to the circuit board. Do this with the power disconnected from the radio.
完成的
I have a problem with my 1999 porsche boxster. The radio comes on then immediately off at start up. After driving a few minutes it will turn on when I hit the brakes, use a turn signal, hit the power windows or just by itself. BUT it also happens with other accessories; like my electric convertible top won't work, door open alarm won't chine, seat belt alarm also.. Fuses seem okay, but I'm so lost on finding the problem. Any advice would be greatly appreciated.
完成的
显示更多的5条评论
添加一条评论
Try bypassing the pioneer fuse/resistors in the pioneer wiring harness and then if it fixes your problem replacing it with a new harness from ebay,it fixed my problem
这个答案有帮助吗?
得分 1
5条评论:
Can you send the link with the exact one you purchased on ebay?
完成的
I finally found out what was causing my problem,it was NOT the harness.It was the weakening of the metal contact springs on the faceplate connector.I finally cured it by easing out a couple of the contacts slightly on the end of the actual faceplate unit but it still causes me on/off problems on a regular bases.I believe only the replacement of the whole of the contacts part inside the unit (which i dont think you can actually buy) or a new head unit would permanently cure this problem
完成的
I have a DCH-P47DH that cuts on and off when I hit even a small bump. I get 5 high pitched beeps when it cuts out, then a single beep when it comes back so there's some sort of signal associated with the problem. I'm beginning to suspect the faceplate connector but no hard evidence yet. Everything else works.
完成的
My avh 201ex double din suddenly turned off once going to work like a 3 weeks ago. And just yesterday it turned on when i moved my car, but in the morning i checked again and it was off. I had already opened up the console and check for burnt fuses and loose wiring but everything seemed to be intact. I thought the stereo didnt work anymore but since it turned on last night, im guessing it still does. What can it be???
完成的
This a problem reported on just about every Pioneer that I have read reviews on. I have the same issue with mine. Several have mentioned that it starts doing this just after the warranty has run out.
完成的
添加一条评论
Hi @anhhung408,
If you’re using the Pinoeer ND BC8 rear view camera have you checked the settings as shown in the user guide -p.35-36?
Here’s an image of the relevant section.
(click on image to enlarge for better viewing)
这个答案有帮助吗?
得分 1
添加一条评论
Decibel settings are to high, and balance in left mid l, left mid and right also in right speaker does "Radio check it self if to much power is going to the radio", nothing wrong if cables are correctly connected. But to high amplified sound settings can make the radio to go off because to much power is taking out of the battery. If you set all 5 channels 100 decibels and 110 dB and 10 for the speakers,
radio settings can make the radio go off in till you disconnect the music source and set the settings correctly.
这个答案有帮助吗?
得分 0
添加一条评论
ive been told its something todo with a memory ic chip inside and a resister problem that's all I know someone on ebay knows the problem and he said he can fix it cheap I wish I knew what the problem really is so I could repair it myself
这个答案有帮助吗?
得分 0
2条评论:
When I turn my jeep off the player is fine. When I restart there is no power. If I disconnect the battery then reconnect it it will work until the next time I turn off my ignition. Any ideas??
完成的
I turn my player on then while driveing it just shuts down could be off for a week then just comes back on it just keeps doing this sometimes it's on for a week then shuts down again for a week or two what's wrong
完成的
添加一条评论
I have this same issue.. its in a vauxhall/opel/GM depending where your reading this. Originally it would flicker off for a second and lose all settings so was an issue with permanent live.. i needed to change the permanent and switched live over (Vauxhall idiosyncrasies) after doing this the same fault would happen but would not lose settings, so perm live is now steady.. i then added a tap wire to from perm to the switched live feed in order to give a steady 12v supply. As soon as i make the connection, cabin fans start up and stop upon disconnect.. same happens with the head unit so all working as planned.. however whilst driving the radio still loses switches live even though it has a permanent live tap running to it… really driving me mad now. Think the only option left is to get a new head unit and see if that cures it
这个答案有帮助吗?
得分 0
1条评论:
I have a Erisin es7973p been great for a couple of months now it wont switch on without given it a tap on the top or bottom then it comes on and works fine now and then it might switch of checked wiring and ribbons they seen ok. Any help
完成的
添加一条评论
I have a problem with my sph-da120. It get stuck on splash screen. Then turn off and it’s trying again. All the time. I checked everything except the memory card inside. Also the cooling fan looks like it doesn’t work at all. Or it is not turning on because the unit is struggling. Any help please ?
这个答案有帮助吗?
得分 0
1条评论:
It could be cutting out because the fan isn't working and its overheating. May need to replace the fan
完成的
添加一条评论
The problem is. We all have the same issue. Different car different pioneer head unit. My old one which I had switched out did the same. When driving the head unit turned off. My personal experience was if I hit a bump it turned off or on. After a month or so of this it stop working completely. So I replaced with an updated one. Not even two days it did the same however I notice for myself I was playing music with the volume up. It’s been a week and it been on 11 or 12 volume. No problems yet. Btw, I put heat shrink tube on all the wires thinking this can eliminate the problem. I checked the fuses as well. Any help would really help.
Thank you in advance,
这个答案有帮助吗?
得分 0
添加一条评论
I still deal with this same issue. At first I though it was heat related, however, it did this last winter on a 5 hour road trip. I have the Mistro unit per Crutchfield’s recommendation. It’s programmed and all functions work as advertised. My wife has the same head unit with no interrupted power issues. Hers only has an adapter kit for aftermarket to factory cables, no programmable unit between. Mistro may be the issue at this point.
这个答案有帮助吗?
得分 0
2条评论:
I managed to fix it. My unit had a 4 gb memory card inside so I change it to a 16 gb and load the software on that one. Now it’s workin perfectly. Hope this helps.
完成的
To clarify, you took the repair access panel off to gain access to internal components? I have no slot access on the outside of my unit, unless this is the Maestro unit and I missed that feature.
完成的
添加一条评论
Hello my Pioneer SPH-DA160DAB radio turns on then when the car starts turns off and won't turn back on, like no power is going to the radio at all ? All lights go off on the radio, takes around 5 mins to reset for it to come on again with the engine back off, only does this in the morning when the car is cold, never done it in the summer time .
这个答案有帮助吗?
得分 0
添加一条评论
Pioneer DMH-C5500NEX does it sometimes
using maestro rr 1
这个答案有帮助吗?
得分 0
3条评论:
I have a pioneer Avic 5000nex my battery went out I replaced it and now my speakers are not working I had thos problem before I ordered a chip and it fixed it I lost the chip need to get a new one any info can help
完成的
My pioneer car stereo all functions work but I can’t get any sound from the speaker can anyone help me with this issue?
完成的
I have same problem , my speakers won’t work after pulling a fuse
完成的
添加一条评论
Overheating or a wiring issue may be to blame if your Pioneer vehicle audio turn off by itself. Your car stereo will cut off automatically if the internal components overheat.
这个答案有帮助吗?
得分 0
1条评论:
Need help please, so I have pioneer Avic 5200 and the last few years have been dealing with driving and radio goes out, doesn’t happen right away but maybe 10-15 mins into drive the radio goes out, then comes back on- so on and off— I just bought another pioneer head unit to see if it was that but no the brand new unit turns off also!! Anyone know next step? It worked fine for the first 3-years- then started acting up
完成的
添加一条评论
I had this problem with my pioneer what I did is I cut down my sending unit wire also then It still did this when the truck was off and the truck was started and running pushing power Yes I'm running two batteries It worked just fine
这个答案有帮助吗?
得分 0
1条评论:
Firmware update fixed it for me.
完成的
添加一条评论
Firmware update fixed it for me. No issues for the last year.
这个答案有帮助吗?
得分 0
添加一条评论
I've got a DEH-S24220BT. When driving and using Bluetooth (phone volume at max), if I turn the stereo volume past 20-25, it will shut down. It will then turn itself on and off repeatedly until it finally comes back and plays. Sometimes it's back in a couple minutes, sometimes it'll take hours and hours.
Fuses and wiring have all been checked, rewired, and rechecked. The unit is maybe 6 months old.
这个答案有帮助吗?
得分 0
2条评论:
Hi @cvos89n8cqtyp7k
Have you checked if the latest firmware is installed?
完成的
I have no idea how to do that.
完成的
添加一条评论
添加你的答案
Francisco 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 118
过去 30 天: 614
总计 225,162
