跳转到主内容
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
73 个问题 查看全部
F150 2014 Iwe4x4 grinding and rubbing sound in 2wd and In 4wd
I have a 2014 stx 4x4 that keeps having grinding and rubbing sounds coming from the front end. Sometimes it comes when just driving in 2wd the other times when shifting into 4wd. I took it to the dealership 3 times so far. The first time they said they replaced all 3 IWE'S. The sound went away for a week. So I took it back the second time they replaced the front axle and the solenoid for the IWE. They had it for a week this time I picked it up friday and its still making the whinning and grinding sound like its partially engaged. The truck was sold to me certified pre-owned and only has 19,000 mi. Has anyone else had these same problems?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
Hey James,
I found a forum post that might help. Check This out. Sounds like if you already replaced the solenoid, you may have to replace the IWE. There's a trick in there about driving 4x4 or pulling vacuum lines to have the truck drivable.
Cheers
这个答案有帮助吗?
得分 2
1条评论:
Thanks I'll check it out
完成的
添加一条评论
I believe there is a technical service bulletin (TSB) for this issue. I had the same issue and the repair included installing a vacuum check valve at the solenoid.
这个答案有帮助吗?
得分 0
添加一条评论
Se dañó la climayera y no ay porque es electrónico
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James Starrett 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 20
总计 8,962
