跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Laptop only works when plugged in
I spilled a bit of water on my computer and ever since everything has been working fine, except I can only use my computer when it's plugged in. The battery icon at the top says 100% and the light on the magsafe is green. I ran a battery diagnostic and it says everything is working fine. If I'm using the computer and the cord comes unplugged it just shuts off.
Like I said, everything else is working fine, it's not running slow or getting hot. What parts could be the issue?
Update (09/01/2016)
Oh I should add that I already tried an SMC reset to no avail.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Give this gem of an app a try to check things out: Coconut Battery. Its a free app! Snap a screenshot of the main screen and if you can try pulling the power cord while the system is running to snap a second capture. Post them here so we can see.
这个答案有帮助吗?
得分 3
添加一条评论
You need to replace the battery as im on the same with my samsung laptop and i got a new battery and now it all works fine , good luck
这个答案有帮助吗?
得分 0
2条评论:
@Coco - Very different animal ;-}
As this was water damaged it could be a few different things. Doing some level of diagnostics would be a smarter direction here.
完成的
I agree completly
完成的
添加一条评论
添加你的答案
Kate Morics 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,101
